| Posted by Chuck on November 15, 2001 at 21:43:20: | |
| In response to Re: leaking toilet | |
: : Hi, : : I just wanted to know how you would drain a toilet of it's water if it were not going to be in use (or replaced)..There was a leak we noticed and we thought if we turned the water supply valve off and then flushed the toilet,the rest of the water would drain out of the bowl and tank leaving it empty and ready for removal.We haven't done this yet because we don't know what the outcome will be and don't want a flood.Thanks for any advice! : : Amy : When Im removeing a toilet and dont want to make a mess I use a shop vac.Mike Mike, to suggest someone to remove a toilet with capping it off might cause a hazardous condition.
| There are none. |
