Re: Waterproofing a tiled tub/shower surround
Posted by Casman on November 14, 2001 at 12:11:22:
In response to Re: Waterproofing a tiled tub/shower surround
: I'm going to install a ceramic tile tub/shower surround. Some of the books I've seen recommend a waterproof barrier placed under the tiles, others say just use the normal plywood/wonderboard/tile combinations. Is there a reason the simpler approach can't be used in this wet location? The thought of slapping waterproof felt down with asphalt adhesive sounds like a nightmare waiting to happen. : Randy All I did was staple up some felt then placed the rock-wonderboard over it, I didn't use any asphalt adhesive or whatever your talking about doing,,its just a secondary protection I think...good luck
Replies to this post
There are none. |
