| Posted by hj on November 14, 2001 at 07:58:53: | |
| In response to Re: Drain for washing machine backing up | |
Save the $8.00 and call a plumber. The HD snake will not be big enough, probably will not be long enough, and you will not know where to insert it to do the proper job. : : The hooked end of the hose for the washing machine is placed into the drain. When washer goes into cycle where water is drained out, it empties some ( only a few seconds ) then starts backing up out of the drain and water runs onto floor. I used wire to run down to unclog whatever, but that did not work. What shall I do?
| There are none. |
