Re: Drain for washing machine backing up
Posted by MikeStheplumber on November 13, 2001 at 22:48:49:
In response to Re: Drain for washing machine backing up
: The hooked end of the hose for the washing machine is placed into the drain. When washer goes into cycle where water is drained out, it empties some ( only a few seconds ) then starts backing up out of the drain and water runs onto floor. I used wire to run down to unclog whatever, but that did not work. What shall I do? If the drain isnt blocked and it still backs up the pipe it drains into might be long enough(it should be 36 inches long).If this dosent fix it post back and Ill see if I can help you.Good luck Mike
Replies to this post
There are none. |
