Re: CUTTING CLAY SEWER PIPE
Posted by MikeStheplumber on November 13, 2001 at 22:22:47:
In response to Re: CUTTING CLAY SEWER PIPE
: I NEED TO CUT THE HUB OFF OF A 6" CLAY SEWER PIPE TO INSTALL A RUBBER BOOT TO ADAPT TO PVC. HOW DO I DO THAT WITH THE PIPE PARTIALLY IN THE GROUND WITH OUT BREAKING THE PIPE. THE EASIST & SIMPLEST WAY POSSIBLE. I like to do it the old fashioned way with a hammer and a good sharp chisel.Its not as easy as a sawsall but its a lot cheaper if you dont own an electric saw.Good luck Mike
