Re: Squeal during shower
Posted by MikeStheplumber on November 13, 2001 at 21:37:08:
In response to Re: Squeal during shower
: When I run the shower there is an occasional squeal. Starts high pitched and then slowly goes to a low pitch. Only occasional, about 3 times in an average 10 minute shower. There is a small reduction in water pressure during the squeal.
: Any ideas what this could be? It could be a lot of things.Usually something like this is caused by a valve partially opened or closed.First check and make sure all your valves are open in your house,espescially the one on your water heater.Then check the shower head to see if it is clogged.Without being there it would be hard to say for sure.good luck Mike
Replies to this post
