Toilet won't drain and fill back up
Posted by Caroline on November 08, 2001 at 00:00:36:
When I flush my toilet, it fills up to about an inch below the top of the bowl and then slowly drains. It then drains until it the water lever is barely visible in the bottom of the bowl and makes slurping sounds. I can't even put any toilet paper in it because there isn't enough pressure to suck it down the drain so it sits in the bottom. I've tried pouring large amounts of water down the toilet and tried plunging it too. What could be the problem?
Replies to this post
There are none.
