| Posted by hj on November 07, 2001 at 23:09:34: | |
| In response to Re: baseboard v. radiators | |
I assume this means you are also going to replace the piping system to a loop main with diversion fittings and valves on each radiator. Radiators heat differently than baseboards but as long as the system is sized and piped correctly there is no reason not to do it, other than aesthetics. : I an planning to replace my hot water baseboard radiators with cast iron radiators (not the baseboard type). Will this keep the house as warm as the baseboards? Any reason I would or would not want to do this? Doing it for aesthetic reasons.
| There are none. |
