| Posted by MikeStheplumber on November 06, 2001 at 14:16:23: | |
| In response to Re: drain field | |
: I hit a pipe with a steel stake the pipe comes from the sepic tank out to the drain field, how can I replace this section of pipe? Thannk you in advance for any help you can provide Put duct tape over the hole and pour concrete around the pipe.One bag should do it.Good luck with your repair ,MikeStheplumber |
| There are none. |
