| Posted by hj on October 30, 2001 at 22:54:16: | |
| In response to Re: Help wiring a well pump | |
You really need the pump's wiring diagram since making wrong connections could burn out the motor. But from your description, the feed wire would go to the LINE connections on the switch and the pump would connect to the LOAD terminals. : I am going to try to install a red jacket 3/4 hp pump in my new 150 ft deep well next weekend. I need some advice about wiring up the pump and pressure tank, my pump has 3 wires, a green, and 2 blacks, my pressure swith looks like it has connects for 4 wires, how do I wire up this system, any other advice will be very helpful. : Thanks for any help, Don
