| Posted by Brad on October 30, 2001 at 12:24:39: | |
| In response to Re: Expansion tank: in- or out-flow line | |
: : Should an expansion tank be installed on the in-flow line or the out-flow line of the water heater, or does it even matter? : On the inflow, cold water side. Would the expansion tank installed on the outflow/hot water side cause hot water to flow backwards out of the water heater and into some of the other lines, like the bathrooms?
| There are none. |
