| Posted by hj on October 29, 2001 at 08:59:43: | |
| In response to Re: Honeywell diverter valve | |
The colors are usually immaterial. The important knowledge is what is supplying each wire. For that information you need a wiring schematic for your system and the Honeywell valve. If we gave you the wiring that we normally use and it were not the same as on your system, the valve could be damaged or destroyed. : On my central heating system I have fitted a Honeywell Sundial Y plan 3 position diverter valve type V4073A1062-7. : I would appreciate your advise.
| There are none. |
