| Posted by hj on October 27, 2001 at 09:22:34: | |
| In response to Re: tank bolts for toilet | |
If I had to guess, that usually implies that you put metal washers on the bolts before you slid the rubber washers on the bolts. If so, remove the metal washers or you will never stop the leak. : How tight should I tighten the tank bolts? The nuts holding the bolt to the tank is pretty tight but is still leaking (slowly). I'm afraid I might crack it!
| There are none. |
