Low hot water pressure at end of the run bathtub
Posted by Barb on October 24, 2001 at 19:24:25:
Hi, I have hot water at all fixtures except for my tub which is the end of the plumbing run. The hot water will not run at all. It has been slowly decreasing over time but remained adequate. The house was built in 1955 and has galvanized plumbing. I don't seem to be able to loosen the pipe inside the wall. It is tight as a drum. Any insight would be appreciated! Thanks Much, Barb
Replies to this post
There are none. |
