| Posted by David W. Herring on October 24, 2001 at 10:27:43: | |
| In response to Re: CPVC vs PEX | |
:You can't go wrong with either material. If you go with PEX I would go with Mercury Plastics. They use electron beam to cross-link molecules and the product is stonger. I'm plumbing a small country house and am looking at CPVC and PEX. What are the pros and cons? : Here are some I found: : CPVC: cheaper, easy to install, been around a while : What else can you add? Like I mentioned I'm building the house so all the walls are open now. Copper is : I read the archives and noticed you said you have been using PEX and copper together lately. : Also what would you recommend for a supply line running underground about 100'. Also for outside faucets : Thanks,
| There are none. |
