Re: Leaking anti-siphon sill cock
Posted by Nick on October 18, 2001 at 17:24:13:
In response to Re: Leaking anti-siphon sill cock
They are generally repairable, depending on the brand of the products. The top cap generally snaps off, allowing you to un-thread and replace the vacuum breaker assembly.
Good Luck
: I installed 3 non-freeze sillcocks and one leaks water through the anti siphon plastic cap when I attach a hose with a sprinkler or any other restriction. Is this repairable? or do I have to replace the sill cock? If repairable how do you take the valve apart. It seems that the plastic cap cannot be removed without destroying it.
: Thanks
Replies to this post
