| Posted by More on October 14, 2001 at 23:21:10: | |
| In response to Re: Watts T23b pressure reducing valve | |
Your chances of repairing the Watts pressure reducer are good, in the event you can find a manufacturer that still supplies the diaphragm. You might first chect the local plumbing supply house to discover if the cost for a new 3/4 inch pressure reducer is less than the cost of trying to rebuild the Watts. : I have a 3/4" watts T23B pressure reducing valve in my 15 year old home- it is weeping at the stem, so I I am fairly certain the diaphram is worn. Problem is, the valve is in a location that makes replacing it difficult- and, it seems, watts doesn't make this valve anymore. What are my chances of being able to rebuild this and stop the leak (small, but annoying)?? : Thanks in advance.
| There are none. |
