| Posted by Terry Love on October 13, 2001 at 15:52:46: | |
| In response to Re: Replacing toilet | |
: I'am planing on installing a one piece Toto Ultarmax toilet. But I need some advice before I can install. My present toilet (two piece) butts right up to the wall. I've measured from the wall to the toilet tie down studs. Rough-in looks like it is 11" from the wall and not 12" like in the specs. Will the Toto Ultarmax fit there. : Thank You The Ultramax will work with 11-1/4" from the wall, if the flange and drain is a 4" you may be able to move the bolts out that extra 1/4".
| There are none. |
