| Posted by K on October 09, 2001 at 15:57:55: | |
| In response to Re: Tub Drain Plug - how to remove it??? | |
pull it up as far as you can. Then look for a screw between the plug and the tub. Loosen that and then you can remove it. : My tub is slow draining and I would like to remove the hair that I know has probably accumulated around the drain plug but I do not know how to remove that plug. I am not sure what I have but it is the kind of tub plug that you twist and it drops down to plug the tub and to drain it you lift and twist. I have twisted, twisted, and twisted but nothing seems to unscrew. How do I remove the darned thing. I tried drano hoping it would dissolve the hair but no such luck.
| There are none. |
