| Posted by Terry Love on October 09, 2001 at 12:36:53: | |
| In response to Re: Soldering valves | |
![]() : What is the secret to soldering a 3/4" valve to 3/4" copper pipe. The valve is a standard sweated fittings ball valve and the pipe is standard 3/4" rigid copper pipe. I've never really had any problems with pipe fittings, but trying to get this valve to seal with the pipe seems very difficult. I recently moved to a higher altitude (8,500') would this make any difference. Whichever side you are soldering, you will need to have open. That means, opening a faucet somewhere to let heated air out. You cannot heat air and not expect expansion. The last joint you solder will leak in a closed system. If you have already done that, you need to properly flux and heat evenly and that should do it. |
