Re: HELP ME PLEASE
Posted by hj on October 08, 2001 at 08:21:29:
In response to Re: HELP ME PLEASE
The green is the ground and the other two are both hot. But if you are not sure of how to wire it, have an electrician do it since you will be working with 240 volts and can cause serious damage if you do it wrong.
: I'VE RECENTLY PURCHASED A KENMORE HOT WATER HEATER,& I'M NOT SURE HOW TO WIRE IT SO IT WILL WORK FOR ME.CAN YOU HELP ME WITH THIS PROBLEM?THE WIRES THAT ARE ON THE HEATER ARE BLACK,BLUE,&GREEN,WHICH ONE IS HOT & WHICH ONE IS NOT?
Replies to this post
There are none.
