how do you cut cast iron stack
Posted by Brian on October 07, 2001 at 22:54:08:
I need to tie into my cast iron stack in the basement with a drain for my kitchen sink. There is no spot in the hub on the needed side for this tie in. I was considering cutting out a section of the stack from the basement floor to the basement ceiling and replacing with PVC and the necessary connections for the kitchen sink drain. HOW DO YOU CUT THROUGH THIS STUFF????? Any other suggestions regarding this do-it-yourself project would be greatly appreciated. This is all due to a kitchen remodel and the need to re-route the drain plumbing.
