| Posted by DJ on September 26, 2001 at 22:47:52: | |
| In response to Re: Rough plumbing under a slab | |
First determine if tub is left/right drain and look at the specs for the tub. If you make a 6" square around the stub can do any final adjusting. : I am building a backyard workshop on a slab and am including a full bath. I need to know how to determine where to stub up the drain line for a standard tub/shower and how large of a void in the slab is required for the trap.
| There are none. |
