| Posted by hj on September 25, 2001 at 23:05:26: | |
| In response to Re: Garbage disposal trips circuit breaker | |
GFCI's are notorious for tripping prematurely. A circuit breaker will trip due to a power overload. GFCI's trip when they even suspect a power leakage. Since disposers combine electricity and water, they have a higher possibitlity of false tripping. But if the motor seal is bad and water gets into the motor the GFCI will definitely trip, since that is what it is designed to do. Disposers are not typically connected to GFCI's. : The breaker this thing is on was a GFCI. 1/2 hour ago I got back from Home Depot with a replacement breaker and a replacement disposal. I replaced the breaker and everything worked fine. But that was not good enough for me, so I put the original breaker back in and of course, everything worked fine. : The new breaker and new disposal are sitting on my dining room table. : My suspicion is that the disposal is internally leaking onto the motor. Someone who knows what disposals actually look like inside might validate whether this type of leak is possible. To continue with my theory... After not using it for a while everything dried out and it worked fine. I will return the breaker ($38 - GFCI), but hang onto the disposal for a week or two and wait for the thing to fail again. : I do think I have ruled out the breaker. Anyone disagree? : Peter : : : : Why might by garbage disposal trip the circuit breaker it is on? Does this mean it is time for a new disposal? I have isolated the tripping of the breaker right to the disposal, so I know it is not the wiring, the disposal switch or some other thing in the circuit. : : : Thanks
| There are none. |
