| Posted by Chuck on September 25, 2001 at 19:50:29: | |
| In response to One opinion | |
Take it off and bring it to the supply house. It probably screws off, unless there is a set screw on the bottom. : How does the "spigot-to-shower" control work. We have an OLD Delta tub/shower installation and when you pull the control up, water goes to the shower head but also sprays ACTIVELY from the spigot. Is something worn, dirty or missing? Can I disassemble it (the spout) to clean or check something or do I have to replace the entire spout assembly to correct the problem (and does it have to be a "matching" unit...Delta, same model, etc.)?
| There are none. |
