Re: Sand accumulating in pressure tank
Posted by robin on September 18, 2001 at 10:10:07:
In response to Re: Sand accumulating in pressure tank
Hi Ed, I`m wondering if you had any luck with your inquiry. I have the same problem and now my pump seems to be running all the time as well. Thanks, Robin: I have a submersible pump in my well which supplies my house and an apartment in my barn/shop. I have a whole house filter in the house but not in the apartment. I had to replace the tank cross on the apartment pressure tank and notice quite a buildup of coarse sand in the inlet/outlet pipe. I knew sand was coming out of the well since seeing it settle in the toilet tank of the apartment. I am going to install a whole house filter on the supply to the apartment plumbing at the point before the pressure tank. I believe my submersible pump is at 48 feet. Would raising the pump a few feet help alleviate the draw of sand into the plumbing system? Any comments would be welcome. Thanks.
Replies to this post
There are none.
