Re: American Standard overflow problem
Posted by hj on September 16, 2001 at 08:51:32:
In response to Re: American Standard overflow problem
Replace the Mickey Mouse fill valve that American Standard uses with a new one. : Terry, : My American Standard,6.0lpf/1.6gpf toilet will not shut off. The yellow refill mechanism in the toilet is not working. The yellow casing contains two soft plastic washers and a silver dollar size hard plastic piece which also connects to a hard plastic tube (length of a pencil).In the past, I removed the internal parts and soaked them in vinegar to remove calcium deposits. The vinegar trick is not working anymore and I'm getting frustrated with always having to stop the water flow thru the valve below the toilet. I went to Home Depot and Lowes for advice and walk away with no new ideals. I need help big time.
Replies to this post
There are none. |
