| Posted by hj on September 15, 2001 at 10:09:52: | |
| In response to Re: Hot water in cold water line | |
There can be several reasons for the problems, most of them because of the way the pipes are installed. About the only serious reason for hot water in the cold pipe would be a leak in the hot water pipe which is allowing the hot water to surround the cold pipe and create a section of hot water which is then extracted and then the cold water will flow through too fast to be reheated until the flow stops. : For some reason or other the cold side faucet in the kitchen, the point nearest the hot water : Tro Harper
