Re: need to find a way to repair large bathtub spa
Posted by Bath Wizard on September 15, 2001 at 09:23:37:
In response to Re: need to find a way to repair large bathtub spa
Check out www.bathwizard.com for a simple repair kit for this problem.
: : with small crack leaking into the basement. is this repairable and can you recommend a kit? thanks.
: Fiberglass and Acylic is repairable.
: You will want to make sure that it is supported on the bottom, so the cracked area does not get bigger. Home centers should have repair kits. I think it is well worth it though to bring in a professional for the repair though. They can make it look like new. "Bathtub repair" or "Bathtub refinishing" Terry
Replies to this post
There are none.
