| Posted by hj on September 14, 2001 at 19:54:23: | |
| In response to Re: clogged water pipes | |
No economical way, and if they are small household pipes then the answer is no. If you were to descale them you might have numerous leaks since the scale is often sealing holes in the pipes. : is there a way to clean scaled water pipes (fresh)?
| There are none. |
