| Posted by Ben Dover on September 08, 2001 at 20:23:50: | |
| In response to Re: Toto toilets | |
Hi, Hanekke The ultra-max is already a fairly low toilet if you're talking about the seating position and not the back. The higer tank helps the flush by taking advantage of gravity. This will be a slight sacrifice in flushing a larger steaming dumparoni.I understand that sanitary facilities are more or less a hole in the floor in some Asian countries. This would be an option to consider if you are serious about going lower in this room. Regards, Ben |
| There are none. |
