| Posted by dick on September 07, 2001 at 22:51:22: | |
| In response to Re: whimpy showerheads! | |
: where would be a good place to find a good ole water waster showerhead? these new ones barely get you wet, EVEN if you do take out the restrictor! Home depot sells a big chrome head with about 40 brass nozzels sticking out of it. Remove the restrictor and then drill out about half the nozzels with a 1/16 drill. I have only about 45 psi water pressure and this works great. I your pressure is higher , you may want to drill out more of the nozzels.
| There are none. |
