Re: shower drain removal
Posted by hj on September 04, 2001 at 23:12:50:
In response to Re: shower drain removal
The drain is secured to the shower base with a locknut, so you have to free it from the drain pipe. Most of them are fastened with a rubber gasket that will slide off the pipe when you raise the shower base.
: any advice on how to remove an old shower drain from an old fiberglass shower pan would be greatly appreciated.
Replies to this post
There are none.
