| Posted by Max Seigneur on August 28, 2001 at 22:12:41: | |
After installing this new water heater our hot water has a bad odor, like a sulpher smell. Had our water tested and was told that this is a comon problem and that all I needed to do was remove the anode rod from the unit, cut off the anode rod and put back the screw in cap. I'm reluctant to do that thinking the rod must serve some purpose. What would you suggest? |
