| Posted by hj on August 22, 2001 at 22:49:03: | |
| In response to Re: home sewer vent design | |
Water will rise to the level of the lowest overflow point. When a sewer backs up, the first indication is an overflow from something. In your case it would be the basement toilet or shower stall. When the city sewer backs up, the lowest basement/toilet in the neighborhood will be the first to fill up. : Why is this necessarily true? Wouldn't it depend on the level of the sewer line in relation to the level of the basement, assuming a blockage did not force sewage from the upstairs drains into the lower drains (which could happen just as easily in a 2-story structure)? : Anyway, I'd be more interested in thoughts on what to look out for when choosing where to place vents. : : If you connect basement toilets or showers into an underground drain system, there is no way to avoid the risk of a backup. In fact you can almost be certain it will happen at some point. : : : I want to redo all my basement sewer drains, and need some thoughts on vent design. Presently, the only vent for the whole house is on the main sewer line outside the house (no sewer vent in the basement). : : : Any thoughts on what I should look out for? I'm going to put a bunch of cleanouts in the system, incl. one a few feet from the floor of the basement. Any thoughts would be mucho appreciated. Thanks in advance!
| There are none. |
