| Posted by Ray on August 21, 2001 at 06:51:00: | |
| In response to Re: RV Plumbing exploded under floor | |
John: Sounds like you forgot to install the pressure regulator before you attached to city water. The water pressure in my city is about 70 psi. The water pump in your motor home should only develope between 15 and 25 psi. As for locating the leak, if possible check with your local RV dealer and ask them to look at the manual they have behind the counter. Lots of dealers will help you in this. It is usually something they dont want to do is trace a water leak under sprayed foam. Give them a call, cant hurt. Good luck... Ray.. : 1990 Champion Eurocoach (Oshkosh Chassis) Plumbing Schematic : I have a 1990 Champion Eurocoach 35' (Oshkosh Chassis)
| There are none. |
