| Posted by Chuck on August 14, 2001 at 17:40:36: | |
| In response to Re: Toilet repair | |
Try bending the float arm a little if necessary. Some people also bend them to adjust the water level. Another option may be to turn the flush valve so it doesn't hit. But this approach is a little more work. : The float arm keeps getting caught on the pvc tube(overflow tube??). After you flush you have to go in and manually move the arm off the tube so the tank can refill. I tried putting a barrier for the arm on the tube but that was messing with my water levels. There is not alot of area to work with.Please help.
| There are none. |
