| Posted by Stephanie Bickford on August 14, 2001 at 10:59:11: | |
The Float arm keeps catching on the top of th pvc tube (overflow tube???) so that after you flush you have to manually remove the float arm so that the tank can refill. I tried bending float arm and even putting a barrier on the tube so the arm couldn't get hooked on it but this messed with my water levels. tre inconvient. Please help. |
| There are none. |
