Re: removing a jacuzzi tub
Posted by hj on August 09, 2001 at 09:26:00:
In response to Re: removing a jacuzzi tub
Unless you have a very large Jacuzzi or a very small door, it should go through the door once you turn it on its edge.
: We have an old jacuzzi tub that we want to remove from a room. The problem is that it is too big to go thru the doors (the room was built around the tub originally). How can we cut/break a fiberglass jacuzzi tub w/ the least amount of mess???
Replies to this post
There are none.
