: I might not be following you, but if you've :just done it, you can lift the receptor up, :can't you? Lift it up and you'll see what is :not making contact.WRT a shower base, I am not familiar with the term "receptor", or how it could be lifted up. But, he base is made of acrylic and is very rigid. If you have seen a regular fiberglass shower bases at say your friendly neighborhood home improvment store, then this base would be similar. Unfortunately, the mortar has hardened and the base has enough contact to be firmly secured. However, there are these air pockets that are between the mortar and the base in some places, so when you step on them you get a sinking feeling. The base manufacturer states that such a condition can lead to cracking or other problems after prolonged use. I wanted to fix it now while the bathroom was still unfinished. The area near the drain is well attached, so I cannot inject any substance there. However, I do have access to the underside of the flooring and could drill until I encountered an air pocket. For each pocket an inlet and outlet hole would be required to replace the air with something. This is very precarious, since if I drill too far then I will drill through the base itself, I have a whole new set of problems. One of my questions, is does any one have a better solution than drilling or a different technique on drilling? The other is what substances would be good to use as a filler? Silicone caulk? More mortar thinned using water and injected? Jim
