| Posted by Allen Atkinson on August 05, 2001 at 00:09:14: | |
I want to remove a bathtub and replace it with a tile shower stall. The house is pretty old, and the drain line is all cast iron. Since I will be putting the drain in the middle of the shower, it will be about 2 feet furthur from the existing connection. Should I install the new section using cast iron, or can I use PVC, and do they make a PVC to cast iron connection fitting? |
