| Posted by hj on August 04, 2001 at 09:10:23: | |
| In response to Re: disconnect PVC Pipes | |
If this is a residential unit with a 3/4" PVC drain, you will not get a snake through it because the elbows will all be square corners. Use an air compressor and blow the pipe clean. : The floor drain of my air conditioner is clogged. Water goes through PVC pipes to the drain. Now for me to un-clog it, I need to somehow have an opening to insert the "snake." : Since these PVC pipes and joints are glued together (at least I think they are), how can I separate them? : Any help is appreciated.
