| Posted by John Bridge on August 03, 2001 at 17:10:05: | |
| In response to Re: Tile removal from morter bed shower | |
Usually, the tiles pry up quite easily. Get a flat chisel and give it a try. After you've removed all the tile and debris, allow the floor to dry out a couple days (if the shower has been in recent use). Then install the new tiles with thin set mortar. The thin set will repair the dings as you go along. John |
| There are none. |
