| Posted by Ray on August 01, 2001 at 07:03:38: | |
| In response to Re: outside faucet | |
: I have 3 outside faucets protruding through my brick home. they all gush water out the screw in the center of the handle. it gets much worse it I try to use a garden hose with a sprayer.what is the best way to repair these faucets.or do they have to be replaced? - unscrew the nut and remove the stem of the faucet and you will see alittle rubber gasket on the bottom of the valve stem, replace this item and it will eliminate the water problem.
