Re: basement bathroom
Posted by Terry Love on August 01, 2001 at 02:20:02:
In response to Re: basement bathroom
: I'm installing a basement bathroom on conrete. I want to "tap" into the DWV drain without busting up the floor. The toilet has a hole in the floor for it, so that is no problem. For the shower stall, I built it up on a base to put a trap under it. The sink and shower I want to drain into the same pipe just above the floor. The pipe I'm "tapping" into is a 2" dwv pipe. The main drain is 4" where everything is currently draining. The 4" pipe is not near where the bathroom is so I want to use the 2" pipe. Is this 2" pipe only for venting, or is it OK to run the shower and faucet into?
A shower and a lav can drain into a 2" pipe. Without seeing your 2" pipe, it would be hard to tell. It depends on whether it is considered the vent, and possibly plumbed in a way that precludes using it as a waste pipe. It may be possible to "wet vent" in some situations. Your local codes will determine whether it would be allowed in your case.
Replies to this post
There are none.
