Re: Can one put a sewer ejector pump outside of the house?
Posted by Terry Love on August 01, 2001 at 02:13:27:
In response to Re: Can one put a sewer ejector pump outside of the house?
 : Mr. Love, : : I am planning on building a few rooms and a full bath : in my basement. The problem is that the main drain : exits the house right at floor level as there is back fill behind the wall and it runs from there to the : septic tank which appears to be just a little lower than floor level....so I doesn't appear that I have enough drop to install a standard bath assembly using : gravity....so I have thought about using the ejector pump like the "little giant" but was wondering can it : be installed right outside the exterior wall so as not to have the noise and possible oders etc.... : : many thanks, : jeffrey durham Jeffrey, I would check with your local inspector on that. I have seen them plumbed that way, but would want to check with the local authority first. Terry
Replies to this post
There are none. |
