| Posted by Paul Casurella on July 29, 2001 at 01:11:30: | |
| In response to Re: bath drain pipe reroute | |
Thank you for your help. I have it hooked up and it does not seem to be siphoning the water out of the trap. It will make it possible to put a suspended ceiling in easily. : It will work, but it may also siphon the water out of the trap, thus negating the purpose for the trap. It is also an illegal piping connection. : : : The trap of my bathtub is below the joist level of my basement. Can I raise it a bit to between the joists? Instead of coming out of the trap into a four foot almost horizontal run...it would form another curve and drop several inches before entering the run. In other words - drop to trap...come up out of trap...turn down again for several inches...then turn into the horizontal run. Will it work?
| There are none. |
