| Posted by Chuck on July 25, 2001 at 11:44:26: | |
| In response to Re: Shower Pan drain removal | |
The lead can also be drilled out.
: Yes, you can use a sawzall to cut around the drain and then pull the pan up. Since you are replacing the pan, it's headed to the scrap heap anyway. A large hole where the drain was attached won't matter. Terry
| There are none. |
