| Posted by hj on July 19, 2001 at 20:06:31: | |
| In response to Re: RE: Why- - -O- - -Wye? | |
It is hard to determine, from your description, what you are asking as far as how the system is installed. A wye connection is designed to flow downstream and anything entering it will also go downstream, so there should be no reason why the camra or snake did not go the proper way. If you are trying to go upstream, then you need to find another opening or install a second wye in the reverse direction. : The drain in my basement floor runs to a wye which is tilted, the right side leads to an old crok looking thing and it has a gutter sticking into it, which is disconnected at the outside ground level. The other bend heads out and is apparently holding water. The plumber could not get the camera to turn this direction to see what the problem is, also it is questionable if the snake heads there either. How can I determine where in the floor this wye is? The plan is to bust it out and eliminate. The plumber guy quoted me 1500 to tear out all the pipe and replace in what he said would be a 1 day job. Wouldn't it be better to just fix the wye and run a snake definately into the right direction? House is 1890's.
| There are none. |
