| Posted by hj on July 19, 2001 at 20:02:20: | |
| In response to Re: Pump Pressure Switch | |
Most of them are not rebuildable. The freqency of replacement is a function of how often the pump cycles on and off. There is wear only when the contacts connect or separate. You may have a condition that is causing the pump to operate too frequently than the system was designed to. : How often should we expect to replace the pressure switch (Pumptrol in a square D class 9013 type FSG2 SER 6) on our domestic well? This is the third : TX,
| There are none. |
